Password Policy
Using a password policy lets you make sure that your users use a password that meets certain requirements and is secure enough. If you want to activate this feature, check the relevant box in the General section of the Settings tab. Once you check the box, you will see a few other options that you can choose to select to vary the password policy even further.
Last updated
Was this helpful?
#567: Moved Plugin API from Alpha to release
Change request updated
