URL parameters
A URL parameter is a piece of information you place in the browser's URL. Parameters follow a key-value pair[^1] structure and can hold many different types of data.
Parameters are useful when you want a page to carry a small piece of information that survives a reload or can be shared through a link. A common example is passing which item a user clicked to a details page: the parameter tells the page which record to display. They're also handy for navigation, since they work with the browser's back button.
How URL parameters are structured
Every page in your app (except the index page) has its own URL that follows a regular pattern:
https://my-bubble-application.bubbleapps.io/mypageOr, if you've connected a custom domain:
https://www.mydomain.com/mypageThis points the browser to the right domain and page. That URL is really an instruction to the server: your browser sends the URL, and the server responds with the files needed to display the page.
URL parameters serve a purpose too, but instead of talking to the server, they send information to the current page. Your app can write and read parameters in the browser's URL bar and use that information in different ways.
Parameters come after the page URL, separated from it by a question mark (?). If there's more than one, each is separated by an ampersand (&).
Each parameter has a key and a value:
The key identifies the parameter with a unique piece of text, like
name.The value is the data the parameter holds, like
John.
So the structure looks like this:
Placed in the full page URL, separated by a ?, it becomes:
To add a little more, let's rename name to firstname and add a second parameter, lastname:
From this URL, Bubble can read the full name John Doe. Here's how that works.
Reading URL parameters
Reading a parameter is the other half of the round trip: once a value is in the URL, you pull it back out on the page. You tell Bubble which key to look for, and it returns that key's value.
To do this, set up an expression using the Get data from page URL data source[^2].
After picking the data source, Bubble asks for a couple of details:
The key that identifies your parameter. To fetch the first name (John), set this to
firstname.The kind of data to expect. Here, set it to text.
As soon as you set the key, Bubble updates the expression on the right to read Get firstname from page URL.
If firstname=John exists in the URL, a text element using this expression shows John. If the parameter isn't found or has no value, it shows nothing.
Reading different data types
The example above used the text type to read a name. Parameters can also carry other kinds of data.
Reading a data type thing
You can also link to a database thing through a URL parameter. To retrieve the right thing, its unique ID needs to be in the parameter. The parameter's key doesn't affect the result, but when you use Get data from page URL, you set the type to the correct data type.
Set the key that identifies the parameter.
Set the type to the data type of the thing you want to retrieve.
Bubble then lets you add operators to Get data from page URL for that thing. In the example, we're getting the name of the task.
The URL would look like this:
Reading an option set option
You can also retrieve an option from an option set. Options don't have unique IDs, so they're identified by the value in their Display attribute. As with data types, you can give the parameter any key, but you set the type to the option set you want.
Set the type to the option set you want to retrieve.
Bubble then lets you add operators for that option set. In the example, we're getting the abbreviation of the state.
If the state name is stored in the Display attribute, the URL would look like this:
Setting URL parameters
There are two ways to pass a parameter to a page.
FAQ: URL parameters
A URL parameter is a piece of information that you place in the browser's URL. They follow a key-value-pair structure and can hold many different types of data.
Every page in your application (except for the index page) has its own URL that follows a regular pattern:
or if you have connected to a domain:
This points the browser to the right domain and to the right page. The information in that URL is actually an instruction to the server to send the correct page back to the browser. In other words, your browser sends that URL to the server, which responds by sending back the files needed to display the page.
URL parameters also serve a function, but instead of talking to the server they can send messages to the current page. In other words, your Bubble app can write and read URL parameters in the browser's URL bar and use that information for different purposes.
URL parameters are listed after the complete page URL, and are separated from that URL with a question mark (?). If there are multiple parameters, they are separated from each other with an ampersand.
Each URL parameter consists of a key and a value:
The key identifies the parameter with a unique string of text such as name
The value is the data that the parameter holds, such as John
The structure would then look like this:
If we place that in the full page URL (and separate it from the URL with a ? as we explored earlier) we get:
Now to add slightly more complexity, let's change the name parameter to firstname and add a second parameter called lastname.
In this last example, Bubble would be able to identify the full name John Doe from the URL bar. Let's have a look at how that happens.
As we've covered, the URL parameter consists of a key and a value, and we need to instruct Bubble what key to look for in order to get the value in return.
To do that, we set up an expression where we use the Get data from page URL data source.
After picking the data source, Bubble will ask for some additional parameters:
The first one is the key to identify our parameter. We want to fetch the first name (John), so we'll set that to firstname.
Secondly, we need to tell Bubble what kind of data to expect. We can set this to text.
As soon as you set the key, you can see on the right side that Bubble updates the expression to say Get firstname from page URL.
If the parameter name=John exists in the URL, the text element will show the name John to our users. If the URL parameter can't be found or has an empty value, it will display nothing.
In the example above we used the text data type to read a simple piece of information: a name. But URL parameters can also be used to read other types of data.
Custom data type things
You can also link to a custom data type in a URL parameter. To read and retrieve the correct thing, that thing's Unique ID needs to be present in the parameter. The name (key) of the parameter does not affect the result, but when you use the Get data from page URL data source you need to set it to the correct data type, as exemplified below:
First we set the name (key) that identifies the right parameter
Then we set the type to the data type of the thing we want to retrieve
Bubble then lets you add operators to the Get data from page URL data source relevant to that thing. In the example we are getting the name of the Task.
The URL in this case would look like this:
Option sets
You can also retrieve an option from an Option set. Option sets do not have Unique ID's but are identified by the value stored in the Display field. Just like with data types, you can give the parameter an arbitrary name, but you need to set the type to the Option set you want to retreive.
Then we set the type to the Option set we want to retrieve
Bubble then lets you add operators to the Get data from page URL data source relevant to that Option set. In the example we are getting the abbreviation of the State.
The URL in this case would look like this if we included the state name in the Display field:
There are two ways to pass URL parameters to a page:
The first is to include it with the URL when the page loads, for example by linking to the page with a URL that includes the parameters. Simply copy/pasting the URL into a link will have Bubble recognize the parameters on page load.
The second is to use the Go to page action and checking Send more parameters to the page. This will apply the necessary encoding to whichever information you provide and send the parameter.
FAQ: URL Parameters
Can you pass a list of Things in a URL parameter?
You can only pass one value at a time in each URL parameter (but you can create as many parameters as you need, within the maximum URL length supported by the browser). There may be workarounds to pass lists, but it's not officially supported by Bubble at this point.
Are URL parameters secure?
URL parameters are not insecure by and of themselves, but they can require that you understand the potential vulnerabilities associated with using them. For example:
They are fully editable by your users, meaning that they can add, remove and change URL parameters as they want.
They are of course also fully visible in the browser's URL bar, meaning that they should never contain any sensitive data
When used for navigation, keep in mind that a tech-savvy user can pay attention to the URL parameters and understand their structure: if you don't secure your navigation in other ways the user may be able to access sections they are not supposed to
When including custom data types in the URL, you are revealing the Unique ID of that thing. Again this is not a vulnerability on its own, but can lead to vulnerabilities. Someone could for example replace the Unique ID in the URL to see a record that's not their own: the things needs to be protected with Privacy Rules
Last updated
Was this helpful?
